Where Do I connect This Power Cord?
wiinippongamer
yutubemedia
280
no i mean the power connector on the VGA cooler look here it is: http://img684.imageshack.us/img684/3836/rimg0099s.jpg
That is usually plugged into the card where you disconnected the fan on the old cooler - but usually needs to be plugged in before the cooler is attached so you may need to start over in order to be able to access the plug.
yutubemedia
280
okay so i plugged it in, i got it in, now is my card ready to be connected? Is it all good to go?
tahnks
yutubemedia
280
hopefully the VGA cooler is not to heavy for the motherboard to support? Because only the chip that you insert into the PCI slot is supporting it, youu know...oh well
yutubemedia
280
Okay, So I hooked it up and its working, but, the temps are not anything better, in fact they are hotter. Heres the original before temps with stock cooling: http://img593.imageshack.us/img593/9788/gpucputemps.png
And heres the new temps with the Arctic cooler: http://www.youtube.com/watch?v=9mBnR2NJ4po
Now the thing is, there are two different Temperatures listed in the video, which one do i go off of?
wiinippongamer
HWmonitor should detect the 5870 as a whole with just one solid temperature and nothing else, or at least that's how it does it with my 5850.
Use the same software as the first pic for a better comparison.
T any case load temperatures is where the real difference will be noticed, doesn't matter if at idle is about the same, and give the thermal paste some time to cure and it'll drop another 4-5c.
yutubemedia
280
okay so heres using teh same software, And it is 2 degrees cooler, but thats not like much at all. I did noticed though it says only 800RPM, while the image of the stock cooling pics is 1100RPM maby thats why? http://img832.imageshack.us/img832/2349/rimg0106.jpg
If that is why, IF, can i manually increase the fan speed with software?
Also - the temps will vary depending on the ambient temp (room temp) and the fan speed etc. -- to really get an idea if the new cooler is running better you'd need to check the temp under full usage (running a benchmark of some sort that runs the card at full usage) and run both the before and after using the same program under the same room temp. to get an idea of the actual difference.
The idle temps are not going to change much since there is not much heat to remove so even a stock cooler with low fan speed can handle that -- the difference will be under stress when there is more heat to get rid of and whether the new heatsink can remove it better keeping it cooler when running games etc. instead of having it build up.
