Need help- 750watt psu enough?
  • Power Supplies
  • Components
  • Product
Last response: in Components
June 25, 2011 9:34:50 AM
Good day folks- I am changing certain parts of my pc. The machine was originally tailored to run 2 5870s in crossfire, in a AMD Phenom X6 system, and is based on a competent ASUS M4A89GTD PRO/USB3 mobo built for the purpose of OC and XFire, 2 hard drives and some other misc items. The psu to support this was a solid themaltake 750w model.
[Boring]
However in anticipation of the price drops with regards to the Southern Islands chips that may hit the benches in August- I decided to muck about and do a single chip GTX480 config on the board. This setup has run well for the last 3 months, and now as I intend to sell the 480 in the near future as the prices of the chip have gone up. Before that- for reasons too lengthy to add to the page, I am buying a 460 as a dedicated physX card and an overall secondary card. Soooo.... all my jewish machinations aside:
[/Boring]
Will a 750watt PSU be able to support a Phenom X6 based configuration of:
1) 480+460
2) 6970+460
And if not-
3) Can a computer use a PSU that is much stronger then the needs of the components?
4) If yes- what good, quiet PSUs would you recommend for a future-proofing ability to support 2 top range Xcrossfired chips and a dedicated physX card in the guise of 460.
Thanks folks
:bounce:
More about : 750watt psu
a b ) Power supply
June 25, 2011 11:48:51 AM
Yes, you can use a power supply that's way MORE than you need - it will simply draw less current from the supply. There are an awful lot of PCs out there that have a >500W PSU despite the PC drawing only maybe 100-150W.
There are a variety of good power supplies, but for a quiet one, I like the Seasonic X series - just pick one that will comfortably cover your expected draw.
May 26, 2013 7:35:16 PM
i believe there is one that is sold by corsair that will turn off fan when not on load
