Help in choosing a MotherBoard?
Hello,
i want to custom make a DeskTop PC, i was so focused on choosing the Spec's of the PC
and forgot all about MotherBoard, so basically i don't know any thing about MotherBoards,
so please fill me in of what i am missing! or if i am choosing the wrong parts:-
Processors:
Intel® Core
13 answers Last reply
More about help choosing motherboard
  1. Processors:
    Intel® Core
  2. whats your budget?
  3. i don't know why both of posts doesn't show all of the text,
    also why i can't it them!
    http://pastebin.com/CzVfP4h5
  4. actually i don't know,
    because this is the first time i build my own computer,
    & don't know the price range for the motherboards,
    please see my pastebin link!
  5. http://www.newegg.com/Product/Product.aspx?Item=N82E16813131802
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131808
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128531R
    problem is most socket 2011 boards if not all doesnt have an onboard video card.......but on the bright side the 560ti will have one
  6. other that the parts in my pastebin links, i am thinking of:-
    Six-Core Processor & Dual Graphic Cards,
    Regarding the budget for the MotherBoard is 400$!
  7. either of the asus' then ,also which 560ti you plan on getting?
  8. thank you, i don't want onboard video card, so that i can change it,
    would you mind explain the types & specs of a motherboard;
    because i didn't get any of the specs of these 3 motherboards!
  9. Like in RAM,
    there is GB's for Multitasking,
    & Mhz's for the speed given for the working program!
  10. the ASUS Rampage IV Extreme has 8 slots of ram that can hold 8GB each up to 2400mhz clock for ram ofc you would have to overclock the CPU to use rams at this speed ,quad channel means all 8 rams can work stable at the same speed ....what else would you like to know?
  11. DaYiM said:
    Hello,
    Processors:
    Intel® Core
    Click to the link below TESE ARE MY SUGGESTION
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131808 Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116492&Tpk=i7%203930k CPU
  12. if i choose this motherboard well i be restricted of
    choosing the CPU's And Graphic Cards?!
    what is the feature/port name for Dual Graphic Card?
  13. for nvidia its called SLI for AMD its called crossfire
Motherboards Desktops Product
