Ok so I'm using the silverstone raven RV01 case, which vents everything through the top of the case. The PSU is mounted at the bottom of the case. The issue is that the PSU I have takes in air through the bottom, then vents out the back. I dont see how it can get much air this way so I'm just wonndering if I am better off flipping the PSU, over ( So that it takes in air from the top, then vents it out the back)
Any opinions appreciated, Thanks
