Ok , so I apologize for the noob questions, but this is my first build, and i want to do it right.
My NH D14, uses two 3 prong cords, while there is only one CPU plug in that has 4 Prongs. Do I simply plug both fans onto the sys fans (which are 3 prong), or do I use the Y split cable to plug both of them into the CPU plug in (while leaving one prong unused)? Or does it even matter
Thanks!
Thanks!
