[Solved] New Builder need help
Approximate Purchase Date: Next Few weeks
Budget Range: around $1100 including tax/shipping
System Usage from Most to Least Important: gaming (Only use)
Parts Not Required: I have (mouse, keyboard, but i need to upgrade)
Preferred Website(s) for Parts: newegg.com
Country of Origin: US
Parts Preferences: intel
Overclocking: Not as of right now
SLI or Crossfire: Not as of right now
Monitor Resolution: Thinking about buying this------> http://www.newegg.com/Product/Product.aspx?Item=N82E16824001385 (SAMSUNG B2230 Glossy Black 21.5" 5ms- 1920 x 1080_
The basic build that i have in mind is
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129097
Antec Nine Hundred Two V3 ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Intel Core i5-2500K Sandy Bridge 3.3GHz-
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131702
ASUS SABERTOOTH P67
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130565
EVGA 01G-P3-1371-TR GeForce GTX 460
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
Western Digital RE4 WD5003ABYX 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
G.SKILL Ripjaws Series 8GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135201
ASUS DVD-E818A4/BLK/B/GEN Black 18X IDE DVD-ROM Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021
Antec TruePower New TP-650 650W Continuous Power
Total (with shipping)=1072.45
Now i need some one to check that everything will work with the respective components, and that they will all work within the power supply. I'm a new builder, never built my own pc but i need a decent pc that will work for the next 2 years for mmos coming out. I'm not looking to make a beast, just a mid-range gaming pc that can work for at-least 1-2 years before a major overhaul.
Important Questions
Will it work?
enough power?
is this a decent gaming pc, with future updatability?
am i missing anything that is need?
Thank You in advance, needhelp1989
8 answers Last reply
More about solved builder help
  1. $130 for that case ? You'd be spending $20 more on the case then you are on your monitor. Get a SATA drive, not an IDE one. I'd go with a cheaper case, cheaper motherboard and upgrade your monitor and GPU.
    Do you recommend a case, and mother board, I'm kinda new to building computers.
  3. Why not go for the six core amd processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103913&cm_re=amd-_-19-103-913-_-Product
    same price but 2 more cores
    Probably because that 1100T is a crappy cpu ?
    http://www.anandtech.com/bench/Product/203?vs=288 <----- 1100T vs 2500K
  5. I don't see why you think it is a crappy cpu. Most of those benches are comparable to each other. Not to mention the fact that intel invests allot of money to have programs optimized for their CPU. Plus I bet that most of the test are not suited for 6 core CPUs.
    First off the OP stated in his first post on here that his build is entirely for gaming. That cpu like all AMD's suck the big one when compared to the SB cpu's. And for 6 cores...that cpu is a dog imo unless you narrow it down to a few proggy's out there that benefit from it. All in all the SB cpu's mop the floor with any AMD cpu out there at atm including those 6 core cpu's.
    Go to any major site on the net and look at the benchmarks. They all pretty much say the same thing.
  7. The 1155 2500K is far superior to 1100T for gaming if not any other benchmark you'd use it for. I have hopes that the AM3+ Bulldozer will give it a run, but no one knows so far.
    http://www.anandtech.com/bench/Product/288?vs=203
New Build Systems Product
