[HELP] Problem with hd 2600 pro
my main is intel D945GCCR. When I install VGA 9400gt, everything is ok but when I install hd 2600 pro, my monitor doesn't work.
Can every one solve this problem?
Thank you so much
6 answers Last reply
More about help problem 2600
  1. I suggest you go back to the Geforce and unistall those drivers, then go to the Radeon and boot it up.
    It doesn't work. I think hd 2600 pro isn't suitable for my main. I removed the 9400gt and unistall driver, then I installed hd 2600 pro but nothing appeared in the moniter
  3. Are you plugging in the monitor to the card? So if you boot no BIOS screen and no Windows loading screen
  4. Some versions may have come with a 6pin power connector and if there is one you need to hook that up. If all else fails then chances are that the card is doa (dead on arrival) and you need to return it. PS that 9400gt would likely have been better in some games any way compared to that 7600gt.
  5. I thought the Radeon 2600XT was better than the Geforce 9400GT in gaming performance.
    It is but he/she had made two other threads about asking for help about this card and the 7600gt.
Graphics Cards Intel HD VGA Graphics
