Is it possible to use parts of a dell dimension 5000 for another dell?
Hello,
is it possible to use parts of dell dimension 5000 for another dell? I've got a broken one here.... I think it's the motherboard, and was thinking about just getting another dell and upgrading it with the parts of this one to make it better. Is
4 answers Last reply
More about parts dell dimension 5000 dell
  1. Hello everyone!
    Is it possible to use parts of dell dimension 5000 for another dell? I've got a broken one here.... I think it's the motherboard, and was thinking about just getting another dell and upgrading it with the parts of this one to make it better. I've played around with putting parts in and out before, but heard that there was a problem with the dell components. Any info will do :)
    Thanks!
  2. Looks like a 5000 is a laptop:
    http://support.dell.com/support/edocs/systems/pblan/
    You could re-use the Hard disk, DVD, or CD drive,
    and if they are VERY similar the RAM, battery, and power supply
  3. thanks very much! It's not a laptop though, just a desktop tower. Hopefully that'll just make things easier... :)
  4. Same holds, minus the battery :)
    Might be able to use the CPU too....from a desktop...
Homebuilt Dell Motherboards Dimension 5000 Systems
