Hello All,
Approximate Purchase Date: I would like to start buying as soon as possible
Budget Range: Would like to stay around 1200, but can go higher if needed
System Usage from Most to Least Important: Gaming
Parts Not Required: pretty much need everything
Preferred Website(s) for Parts: no preference, I used New Egg to shop around so far
Country of Origin: US
Parts Preferences: by brand or type: Intel
Overclocking: Not, now but maybe later when I get a bit more educated on the subject. No means a priority though
SLI or Crossfire: No intentions as of now
Monitor Resolution: 1920x 1080
Additional Comments: I would like to keep it quiet, but will live with it to provide good performance. I am very new to this and have, what I would call a decent understanding of computers. So i apologize now for any stupid questions.
Here is what I have so far, thanks in advance.
CPU
Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950 - 279.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
Motherboard
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - 229.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
GPU
SAPPHIRE 100312SR Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity - 274.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102914
RAM
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D - 129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
POWER SUPPLY
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply- 89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
CASE
SILVERSTONE RAVEN RV02-BW Matte black 0.8mm Steel ATX Full Tower Computer Case - 179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163154
HDD
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - 87.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
I haven't picked out a monitor yet either so any suggestions would be appreciated.
Thanks Again
CPU
Motherboard
GPU
RAM
POWER SUPPLY
CASE
HDD
Thanks Again
