Approximate Purchase Date: 1-2 weeks
Budget Range: Approximately $1200-1250 before rebates (including monitor), going over a bit isn't a concern.
System Usage from Most to Least Important: Gaming, internet browsing, movie watching
Parts Not Required: Keyboard, mouse, OS, speakers
Preferred Website(s) for Parts: Newegg
Country of Origin: United States
Parts Preferences: No real preferences
Overclocking: Yes
SLI or Crossfire: Plan to add a second card on this build
Monitor Resolution: Monitor is old, not very knowledgeable about high resolutions. Looking to spend about $200 on one.
Additional Comments: Looking for decent frame rates on higher settings for current games, and low to moderate noise levels.
MOBO: ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157229
$159.99
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
224.99
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH
http://www.newegg.com/Product/Produ...6820231276&IsFeedbackTab=True&nm_mc=ExtBanner
54.99
CASE: LIAN LI Lancool PC-K62 Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239&Tpk=pc-k62
99.99
GRAPHICS CARD: GIGABYTE GV-R695D5-2GD-B Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Produ...ark=&IsFeedbackTab=true&Page=2#scrollFullInfo
$264.99
FAN: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=Cooler Master Hyper 212 Plus
34.99
STORAGE: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Produ...6822152185&IsFeedbackTab=True&nm_mc=ExtBanner
64.99
PSU: CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
139.99
Total: 1039.92
Any advice or feedback would be appreciated.
Overclocking: Yes
$159.99
224.99
54.99
99.99
$264.99
34.99
64.99
139.99
Total: 1039.92
