Very, very strange problem
Hi!
Since I upgraded my PC from Intel E4500(OC'd), 3GB DDR2, and ASUS P5B-E to i5 2500K (no OC), 8GB DDR3, and ASUS P8P67Pro
my computer has started to shut down (hard reboot, w/o BSOD) when I use anything graphic card related. For example,
the computer works flawless in Safe Mode where I can surf and watch videos for hours, but I soon as I enter normal mode and watch
a video, start a computer game, or surf with GPU acceleration, it turns off.
I've reinstalled Windows, changed HDD, run Memtest86+ for 12h w/o errors, used one memory stick, changed motherboard, and underclocked my CPU. Nothing
works and I wonder if you guys think the reason is my PSU (Antec Smartpower 2.0 450W ~3y old), or my graphic card (HD4830, oddly used
with the same PSU in my pre-upgrade system)? :??:
7 answers Last reply
More about very strange problem
  1. Weird things happen when you use unsupported cpu's.
    http://support.asus.com/cpusupport/list.aspx?SLanguage=en&m=P5B-E&p=1
  2. I'm leaning more towards the graphics card being the problem, but it could be either -- you'd need to test with another graphics card or another power supply to find out which.
  3. You should get a new PSU anyway.
  4. ^ i would have to concur with the PSU being faulty. If the computer is literally turning off, it is most likely a power issue. Although you can get hard shutdowns if something is overheating and reaches shutdown temperature. Check your temps.
    They sure do, but I'm not using my 2500k with my old P5B-E MB, read my first post again..
    The CPU remains under 70C during 100% load. Regarding the GPU, the computer shuts down before it has a chance to reach load, but idle is 30C.
  6. Opps My Bad. I wasn't even going to ask how you got it to fit much less work. LOL
    You did connect the 6 pin pcie power cable right?
    Can you breadboard your old system back together and see if it works with this GPU and PSU?
  7. I have to agree with the folks who said "PSU"
Power Supplies Computers Components
