Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > Azza Solano 1000 case front USB slow
Forum Systems : Homebuilt Azza Solano 1000 case front USB slow
I have this setup:
CPU: intel i5 750
GPU: nvidia geforce 9800 gtx+
motherboard: Gigabyte ga-p55a-ud3 http://www.newegg.com/Product/Prod [...] 6813128412
RAM: 8gb
CASE: Azza Solano 1000 http://www.newegg.com/Product/Prod [...] 6811517004
hdd's: 2x1tb hitachi, 1x40gb Corsair ssd
ok so my system is a beauty if I do say so myself but I am having this problem with the USB slots in the case. if I plug a USB flash drive into the case drives my max transfer speed is like 3mb/s but if I plug it directly into one of the motherboard USB ports I can get up to 28-30 mb/s.
what's the deal with this anyone have any ideas? maybe I don't have the connectors plugged in correctly? the board manual is REALLY confusing on what is what on the pin connectors. but I think I have it right..
any ideas or anyone have a similar situation?
Reply to begna112
The USB port could be shared between other devices on the motherboard level. You're talking about the front panel usb, try moving the USB header that connects it to the motherboard into another USB header on the motherboard, there are typically 2 or 3.
Message edited by Snipergod87 on 03-28-2011 at 10:18:23 PM
------------------------------ Antec 1200, Asus P5K Premium, Core 2 Duo E8400 @ 4.05GHz, Artic Cooling Freezer 7 Pro, DDR2 @ 1057, 3x 6400AAKS Raid 0, 2x Radeon 4780 in Crossfire, 760,900 and 825,950, SilverStone ST1000-NV
Reply to Snipergod87
Hi
I have a similar problem with an Antec 900 case. My front USB ports are really slow and one external disk has problems using them.
Did you get any solution?
Regards
JS
Reply to JohnSeers
not really, I tried switching them like the previous guy said and it kinda worked but only a little. I saw a huge boost when transferring single files but whenever I try moving a folder or alot of files it slows down to rediculously slow speeds. and it doesn't matter which flash drive I use. and the drive on the other end is a solid state drive
Reply to begna112
I serached around a bit and found a few posts suggesting Antec front USB boards are a bit problematic. Something to do with grounding and filters being bypassed. Some people even suggested Antec might provide a new USB front if you asked.
As mine is a new case I am a bit surprised if that is my problem as you would think it would have been fixed. But I think my next step is to ask Antec support.
JS
Reply to JohnSeers
Hi Begna112
Not sure yet if any luck. I contacted Antec support and they immediately offered to send me a new front USB. But they have not confirmed they have done it. Also I unknowingly went through a USA customer support centre so I am not sure that will work. Also confused by the fact my front USB did not seem to match what they had on offer. I will chase them up and see what will happen.
Very nice of them to offer a new front panel but it does not help me know that it will cure the problem.
John
Reply to JohnSeers
OK, some progress. Antec have confirmed they have sent me a new USB front panel but as it is from the USA it may take a few days. They have not told me which sort of panel they have sent me.
Reply to JohnSeers
There are 1555 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 2 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
