Trying to build my first system, based on i5, seeking advice
Last response: in Systems
I had put together this i5 build and was wondering what someone thought of it. This is my first build. I almost went with an Phenom x4 instead however in the end with the build it was a 50 dollar difference between the i5 and the AMD so I chose the i5.
I do plan on flashing the 6950 to the 6970 bios which is why I have selected it.
I know I didn't include a DVD drive, I am taking the one from my old system instead.
If you can think of how I can do this for cheaper or having a comparable gaming system that will allow me to max out the current games please feel free to share that with myself.
Thanks a lot in advance. All parts are from newegg.
intel i5 build
Qty. Image Product Description Unit Price Savings Total Price
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
Model #:Three Hundred Illusi
Item #:N82E16811129066
Return Policy:Limited Replacement Only Return Policy
In Stock
$69.99 $69.99
Western Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:WD5002AALX
Item #:N82E16822136795
Return Policy:Standard Return Policy
In Stock
$59.99 $59.99
GIGABYTE GV-R695D5-2GD-B Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with ...
Model #:GV-R695D5-2GD-B
Item #:N82E16814125356
Return Policy:VGA Standard Return Policy
In Stock
Mail in Rebate Card
$274.99 -$10.00 Instant $264.99
Antec TruePower New TP-650 650W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE ...
Model #:TP-650
Item #:N82E16817371021
In Stock
$129.99 -$50.00 Instant $79.99
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
Model #:F3-10666CL9D-8GBRL
Item #:N82E16820231311
Return Policy:Memory Standard Return Policy
In Stock
$84.99 $84.99
BIOSTAR TH67+ LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Model #:TH67+
Item #:N82E16813138296
In Stock
$104.99 $104.99
Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52400
Model #:BX80623I52400
Item #:N82E16819115074
Return Policy:CPU Replacement Only Return Policy
In Stock
$189.99 $189.99
Subtotal: $854.93
intel i5 build
In Stock
$69.99 $69.99
Model #:WD5002AALX
In Stock
$59.99 $59.99
In Stock
Mail in Rebate Card
Model #:TP-650
In Stock
In Stock
$84.99 $84.99
Model #:TH67+
In Stock
$104.99 $104.99
In Stock
$189.99 $189.99
Subtotal: $854.93
More about : build system based seeking advice
I highly recommend you buy a p67 instead of a h67 board because you cannot overclock with the h67 chipset. Also spend a little extra for the i5-2400k so you can overclock. It is important for eliminating cpu bottlenecks in games. Also if your just gaming, 4gb will be enough memory, so save the money from the memory and get a 2500k and h67 board.
So this would be better?
Also have no experience with previous overclocking. If I decided to overclock I would need a better cooling design than I currently have? Any recommendations on that?
Qty. Product Description Savings Total Price
Item #: N82E16811129066
Return Policy: Limited Replacement Only Return Policy
$69.99
Item #: N82E16822136795
Return Policy: Standard Return Policy
$59.99
Item #: N82E16814125356
Return Policy: VGA Standard Return Policy
-$10.00 Instant
$20.00 Mail-in Rebate Card
$274.99
$264.99
Item #: N82E16817371021
-$50.00 Instant
$129.99
$79.99
i-shop Gift
Item #: N82E16800995066
-$5.99 Saving
$5.99
$0.00
Kingston HyperX Blu 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3B1K2/4GX
Item #: N82E16820104203
Return Policy: Memory Standard Return Policy
-$5.00 Instant
$15.00 Mail-in Rebate
$54.99
$49.99
ASRock P67 PRO3 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813157230
$139.99
Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500
Item #: N82E16819115073
Return Policy: CPU Replacement Only Return Policy
$209.99
Subtotal: $874.93
Calculate Shipping
Zip Code: 11230
Shipping: $9.62
$69.99
$59.99
-$10.00 Instant
$274.99
$264.99
-$50.00 Instant
$129.99
$79.99
i-shop Gift
-$5.99 Saving
$5.99
$0.00
-$5.00 Instant
$54.99
$49.99
$139.99
$209.99
Subtotal: $874.93
Calculate Shipping
Zip Code: 11230
Shipping: $9.62
disabledteacher said:
So this would be better?Kingston HyperX Blu 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3B1K2/4GX
-$5.00 Instant
$54.99
$49.99
Not quite. You're better off spending the extra $15 and getting the i5-2500K as it allows you to overclock (SB are ridiculously easy to OC to 4Ghz stable with stock heatsink). As for memory, your initial G.Skill Ripjaw ram was perfect, just get 4GB (2x2GB) instead of the 8GB.
One last note, if you ever want the capability for CF/SLI you're going to need the ASRock P67 EXTREME4. The current board you have picked out is great board, but it only has one PCI-e slot.
Related ressources
- Seeking Advice for i7-26000K First -Time Gaming Computer Build - Forum
- First time building a gaming computer - Seeking advice ! - Forum
- First time build , seeking Advice on system - Forum
- $600-$630 Budget PC Build - First -timer Seeking Advice - Forum
- First Build - i5 , seeking some feedback - Forum
Bacillus said:
Not quite. You're better off spending the extra $15 and getting the i5-2500K as it allows you to overclock (SB are ridiculously easy to OC to 4Ghz stable with stock heatsink). As for memory, your initial G.Skill Ripjaw ram was perfect, just get 4GB (2x2GB) instead of the 8GB.One last note, if you ever want the capability for CF/SLI you're going to need the ASRock P67 EXTREME4. The current board you have picked out is great board, but it only has one PCI-e slot.
I agree but here is my problem: my build is getting more expensive. Over 800 was already hurting my budget already but with what you recommend to be added now pushing 900.
I would prefer to keep the 2500k however I would like to be able to add a better heatsink since if I have a toy I'll want to play with it
Is there anyway I can shortchange another part of the rig for cheaper? Do I really need the more expensive ram?
Switching the video card isnt an option
I agree but here is my problem: my build is getting more expensive. Over 800 was already hurting my budget already but with what you recommend to be added now pushing 900.I would prefer to keep the 2500k however I would like to be able to add a better heatsink since if I have a toy I'll want to play with it
Another thing I forgot to mention is with HDD's for the same price you'd be better off with the Samsung Spinpoint F3 1TB. If you get it from amazon it's slightly cheaper than Newegg and it has free shipping.
As for heatsink, the best one for the price is the Cooler Master Hyper 212 Plus. It's only $35 and would allow you to stably OC your 2500k upwards of 5GHz.
I understand the desire to cut costs, and it is very likely you could (I'll see what I can find), but getting cheaper ram to save $5 is really not worth it. The ripjaws is meant for SB and the best memory out there for your setup.
With price constraints, keeping with your P67 Pro3 will save you $20 and is all you need. You can also cut another $10 if you get the Antec Three Hundred that doesn't have the LED's (which is what I use..LED's are obnoxious to me). You'd also be able to knock off another $10 getting the XFX Core Edition PRO650W PSU. So with those cuts you'd be looking at around $875 after MIR (not including the 212+). The easiest place to cut some of the cost would be the GPU, but you stated that's not an option.
Amazon has the Cool Master for cheap (30) so since Im breaking the bank anyway....
however the HD I intitially picked is Sata 6g/s instead of 3g/s of the one you selected. I already have a 320 gb 7200 sata 3g/s drive from my old machine I can use for more space if I am cramped for more internal memory. What would the need to switch be for? Just not sure if I am missing something or not.
If I knew of another video card that would give me max performance on Dragon Age 2, etc then I would switch it out but as far as I know at 1920x1020 I need the 2gb of ram for the increase in resolution and I can flash that particular card to 6970.
Newegg doesnt have the board you recommended in stock, gotta try and find it elsewhere if I can.
Bacillus, you are being an amazing help. I hope you'll have more ideas for me when I get up later today
Best solution
Whoa whoa whoa. This is moving very fast, but +5ghz overclock aren't guarenteed. Anything over 4ghz is a plus. 5ghz+ overclocks are on top grade 2500Ks, not all CPUs are made to the same 100%. Some can be made good for use, but not that great for OCs. I think 4.5ghz is a more reasonable overclock. Still high, just not that high.
Get a Samsung F3 1TB, that'll just leave you room for a long time. It's fast and just as good as any SATA III (SATA 6gb/s). Mechanical hard drives (HDD) aren't really optimized for SATA III, SSDs (Solid State Drives) are but not HDDs.
As for a Video card, a 6870 would run DA2 @ 1920x1080 just fine. That'd save you about 50-60$ which could be saving you in your budget.
WAYYYY better option for your motherboard, the P67A-G45.
Assuming you don't want to learn to overclock, the G45 features OC genie which allows pretty quick one button overclocks. They've been worked the Genie's kinks out and from my knowledge gets a good grade 2500K up to 4.5ghz or so. The G45 also has 2 PCI Express 16x 2.0 slots rather than the one of the Pro3. This will allow for future Crossfire if you so choose to do (If you need more power for graphics) And finally, it's just the same price.
Amazon has the Cool Master for cheap (30) so since Im breaking the bank anyway....however the HD I intitially picked is Sata 6g/s instead of 3g/s of the one you selected. I already have a 320 gb 7200 sata 3g/s drive from my old machine I can use for more space if I am cramped for more internal memory. What would the need to switch be for? Just not sure if I am missing something or not.
The F3 is actually faster than the WD. It would also be worth your while to snag the 320GB from your old machine for extra storage if you need/want it.
As for the motherboards, were you planning on the EXTREME4 or the Pro3? I'm assuming the EXTREME4 since it's currently out of stock, but it'll likely be in stock shortly. So unless you need the computer now (hard to wait, I definitely understand haha), you'd be best just waiting until it is restocked.
Regarding the GPU, your performance levels will really depend upon what resolution you plan to be playing at. One card I'd consider is the GTX 560 Ti. When OC'd, it typically performs greater than or equally to the HD 6950. While the 6950 is capable of OC'ing, but the gains aren't as great as from the 560 Ti. To be honest for the small difference in price though I'd probably stick with the HD 6950.
aznshinobi said:
Whoa whoa whoa. This is moving very fast, but +5ghz overclock aren't guarenteed. Anything over 4ghz is a plus. 5ghz+ overclocks are on top grade 2500Ks, not all CPUs are made to the same 100%. Some can be made good for use, but not that great for OCs. I think 4.5ghz is a more reasonable overclock. Still high, just not that high.I apologize for my poor wording. By "upwards of 5GHz" I had meant that it would be <5Ghz, but in the range of 4.5-4.8GHz (as high as I've personally witnessed OC'd with a 212+).
^ Ermm... F3 is actually slower than the new WD Black SATA III HDDs.
And the Pro3 would be worse than the GD45, but the Extreme4 would be 20$ but @ the price, a great board compared to others around the price.
GPU, 560 Ti does not benefit anything in Dragon Age. In fact performing terribly versus even a 6850.
http://www.hardocp.com/article/2011/03/28/dragon_age_2_...
DA2 is an ATI/AMD favored gaming, as devs come into play again. That is why DA2 is one of the games supporting AMD HD3D. Nvidia does the same, IE bad AMD performance in games like HAWX (1,2).
aznshinobi said:
^ Ermm... F3 is actually slower than the new WD Black SATA III HDDs.***, my bad..didn't even realize it was the new WD, had been comparing to benchmarks of the older.
aznshinobi said:
GPU, 560 Ti does not benefit anything in Dragon Age. In fact performing terribly versus even a 6850. http://www.hardocp.com/article/2011/03/28/dragon_age_2_... DA2 is an ATI/AMD favored gaming, as devs come into play again. That is why DA2 is one of the games supporting AMD HD3D. Nvidia does the same, IE bad AMD performance in games like HAWX (1,2).I stand corrected. Had been speaking more in general, rather than pertaining explicitly to DA2. After checking out the 6850's performance in general, and specifically for DA2, I definitely would have to endorse your suggestion.
Hah, all good.
As for generally, yes the 560 Ti does perform better, but it's kind of a back and forth argument. You have most Ti models sitting at 250$, while 6950 2GB models sit at 265$ w/ 20$ MIRs. TI's have the overclock ability, however the 6950 can unlock to a 6970, in which case 570 vs 6970 is about even.
http://www.anandtech.com/bench/Product/292?vs=306
All depends on the games.
http://www.hardwarecanucks.com/forum/hardware-canucks-r...
Basically gives you an idea, the 6950 2GB wins in all resolutions about 1680x1050.
aznshinobi said:
http://www.hardwarecanucks.com/forum/hardware-canucks-r...Basically gives you an idea, the 6950 2GB wins in all resolutions about 1680x1050.
With which this build is now forcing me to keep my old monitor due to the more money I am funneling into my new system.
I have been reading up on the 2500k. I'll make a point about that I didn't feel the need to want to overclock until I saw the performance numbers gained as you push the i5 upward. Plus I do like a technical challenge.
So here is my final pick I believe. The hard drive & heatsink I'll get through Amazon for cheaper:
Shopping Cart
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
Item #: N82E16811129042
-$10.00 Instant
$69.95
$59.95
$59.99
-$10.00 Instant
$274.99
$264.99
-$50.00 Instant
$129.99
$79.99
i-shop Gift
-$5.99 Saving
$5.99
$0.00
MASSCOOL G751 Shin-Etsu Thermal Interface Material
Item #: N82E16835150080
$4.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH
Item #: N82E16820231276
$54.99
MSI P67A-G45 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813130582
$139.99
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
Item #: N82E16819115072
$224.99
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Item #: N82E16835103065
$34.99
Subtotal: $924.87
Now I just wish could find a "cheap" monitor but they are all around 200 but I guess I can suffer 1680x1050 for awhile. I really cannot justify above 1k. Not even sure how I am justifying above 800 lol.
And really wish to try and get this today so cant wait for them to restock. The motherboard selected seems good enough. I do want to learn about overclocking though and seems others are doing well with it even if they dont use the genie.
LMK and any links to some good first build tutorials would be helpful so I can read up before the parts arrive.
aznshinobi said:
get the cheapest 4gb kit. it should only run you 40$ then get a 6870 instead so you have about 80$ back to your monitor budgetRather wait a month or to get a better monitor than to ditch the better video card now for it.
Still unsure about the Ram. Still reading on them, however need to set the PCI N card and then Im going to buy, pray, and hope its all good
Okay, done and done
Grabbed a 500gb F3 instead of the 1TB. I really dont need the extra space. Grabbed the Wireless N PCI & Cooling from Amazon and everything else form newegg.
I'll keep this thread updated when I get the parts and I begin to put them together.
Thanks a lot for the help from all of you
.Grabbed a 500gb F3 instead of the 1TB. I really dont need the extra space. Grabbed the Wireless N PCI & Cooling from Amazon and everything else form newegg.
Rather wait a month or to get a better monitor than to ditch the better video card now for it.Still unsure about the Ram. Still reading on them, however need to set the PCI N card and then Im going to buy, pray, and hope its all good
I noticed you also decided to pick up some thermal paste. Some of the best stuff out there is the AS5 so if you do get any, that'd be the stuff to get.
Also I definitely agree with waiting a little while for a new monitor. To be honest, I use 1680x1050 and really haven't considered a new monitor...it's more than sufficient for any practical gaming purposes. If you really need something high resolution or just a big screen, consider hooking it up to your TV.
EDIT:
Best of luck with your build..should be a great one!
Related ressources:
- ForumProposed i7 based build - Seeking advice
- ForumSeeking advice on a new build
- ForumSeeking advice on first time Hackintosh build
- Forum1st timer seeking advice on an i7 2600K build
- ForumSeeking Stereoscopic PC Build Advice !
- ForumSeeking advice gaming and editing build
- ForumSeeking advice on 1st build
- ForumFirst time build , seeking advice
- ForumBuilding First PC, Seeking Help
- ForumSeeking wisdom on my first build .
- ForumIs this a good budget gaming build??
- Forum[Solved] Here's me using the Corsair 600T, any advice?
- ForumProblem with new P67 build?
- Forum[Solved] My First Gaming Build
- ForumPlanning to build a new pc...
- More resources
