Solved
First Build Case questions.
Last response: in Systems
Hey guys. I picked a Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E168... and i need to find a case with good air flow that will fit it, a 560 Ti or two, and it needs to be under $79.99 USD. I currently want this: http://www.newegg.com/Product/Product.aspx?Item=N82E168... but i don't know if the sound, Ethernet, and other ports on the back will line up, and if it's wide enough. Please suggest and tell me if the case is big enough. Thanks!
More about : build case questions
mattius92 said:
cases and mobos are made to fit each other, so you should be fine. And the Antec case looks good, add a few more fans and that case will have plenty of good airflow.
:p  but if you look at the back of the case, and at where the ports are, they don't fit. I mean like the sound and ethernet port.
Related ressources
mattius92 said:
where the I/O ports are in the back is a plate, you can pop that one out and put in the one the comes with your mobo. Everything should work.
Oh thanks!! lol, it's my first build, i've only done mods. thanks!
Best solution
Wow, I never noticed that - the display has a fake back plate :pt1cable:  . mattius92 is right - all the motherboards come with their own plate, and although it is a pain to get it all to lined up, it should fit perfect when you do it right.
It appears that there are some fans missing from this junior model of the dark fleet. Guess that is why the case has a $20 rebate. There is only an option to add one extra fan on the side. They call that advanced? Airflow should be adequate, but certainly not generous.
Consider this HAF 912 for the same price ($60) without the hassle of a rebate. Now add these 4 additional fans for $17, as follows: 1 extra in the front, 2 on the top and one on the side. Now you'll have very good air flow, and because these are quiet fans, low overall noise.
kk thanks, i'm using my old hard drive for this, and i'll check out the guides and the case. Thanks!
Oh and also, since this is my first build, the fans only have 3-pin connectors. where do i hook those up to?
mattius92 said:
The motherboard will have a couple 3-pin connections for fans, and then the rest should just have an adapter to plug into a standard 4-pin molex cable.
kk thanks
Ask the community
