Hey guys just bought all the pieces needed for my first pc build and just noticed that I couldn't find an internal usb 3.0 on the motherboard any help or suggestions guys?
Z68 Extreme3 Gen3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271&Tpk=Z68%20Extreme3%20Gen3
NZXT Phantom 410
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146085
also on another note where do I connect the fans to the motherboard just on any fan connectors, I believe I had seen a case that the fans where all plugged to a fan controller and then just needed the power to the fan controller thanks guys for all the help any other info that you need please just ask I will be on here for quite some time.
Z68 Extreme3 Gen3
NZXT Phantom 410
