Solved
Is NZXT Guardian 921 a good cabinet?
  • Power Supplies
  • Components
  • Product
Last response: in Components
June 30, 2011 4:19:30 PM
Is NZXT Guardian 921 a good cabinet?I absolutely love the looks,and I want a transparent side panel,which made me choose it over NZXT gamma.But the guardian seems to have a flimsier build quality.Please post your opinions/suggestions about this cabinet.
I also like the CM 430 Elite Black,but sadly it lacks cable management.If there are any cabinets with transparent side windows in the same price range,please suggest them
More about : nzxt guardian 921 good cabinet
Best solution
June 30, 2011 7:17:27 PM
It's currently deactivated at New Egg but if you can find this case elsewhere I say go for it.......The build quality is good and the aesthetics of the case is a plus.If gaming is what you are doing,then this is a great case....And yes you are 100% correct about the CM 430..it lacks sufficient space for adequate cable management,but hey,I am a person who can manage if need be.Twisty ties(cable ties)really help with cable management.There is an optimistic and pesimistic way of viewing cable management.If you bundle the cables so they are easily accessable than that is a plus..but if they become too hidden,then it becomes frustating to upgrade certain parts.Example)I had a hard drive that I desperately needed to change out for lack of sufficient space... I made sure the cables were buried and tucked away and it was a hassle to undo the ties to get to the drive and replace it,so my lesson learned here is actually 2 part...1)never again will I 'bury' my cables away close to my drive...2)get a case with freekin' hot swap bays.Sorry I took up alot of your time hope I helped......
July 1, 2011 2:52:18 AM
Best answer selected by ashikns.
m
l
July 1, 2011 2:55:18 AM
Thank you very much:D
I was particularly bothered about the build quality because some reviews said it used a lot of plastic.I live in India,and it is available in my country.But will it fit coolers like the CM hyper 212+
m
l
