Hello all,
I've been reading forums & reviews for days and I still can't make up my mind. I'm starting a new build for the first time in 5 years. My current machine is a Pentium 4 from 2006. Yup, you read that correctly, a P4!. So, with my new build, I need to do it in stages due to budget. However, I want to start with the best foundation possible - a case that will be ultra-flexible as my budget gets replenished over time. I've decided that price for the new case is basically no object at this point and I plan to load it now with some hand-me-down freebie hardware from friends . Because, after all, any hardware they give me will be leaps and bounds over what I'm used to. Then eventually I want to start replacing (starting with a quality mobo/cpu, of course) all of the hardware over the rest of the year. I can't use my current case as the psu is burnt up and the case/psu is proprietary dell crap and they want a couple hundred bucks to replace psu (it's a separate, completely enclosed unit that mounts on the bottom of the XPS case) - besides it's time for new tech anyway.
These are what I think my case requiments are:
-almost no budget
-supports ATX, EATX, micro ATX
-supports larger GPU's
-very, very quiet (did I say quiet?)
-descent or better air cooling (I'm not sure that I ever want to deal with the mess of liquid cooling)
-clear side panel (to gaze in amazement once I get everything upgraded )
-very clean cable management
-easy to clean and maintain i.e filters (or at least recommendations on after market, washable filters for the appropriate size fans
-semi-toolless or completely toolless
Any quality input is much appreciated!
Sincerely, Nebo
-almost no budget
Sincerely, Nebo
