$500 build help
hey im building a computer for a friend but dont reall have the time to look everything up and compare. im looking for a build around 500-600 and he needs everything other than keyboard monitor and mouse. hes just gonna be using it for music some movies and maybe gaming i have no clue what his resolution is on his monitor either he just says its not high def haha. so im gonna say 1280x1024 or lower. thank you for your help
2 answers Last reply
More about build help
  1. ^ Nice Batuchka.
    I also suggest looking at my 450$ build. You could spend another 50$ on the motherboard so you have room for upgrade, you could upgrade to this board.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813135279
    Then you have 30$ left, that 30$ could be added to the graphics budget to get the 450 GTS. 100$ AR.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127527&cm_re=450_gts-_-14-127-527-_-Product
Build Monitors Systems Product
