R Rupesh Rathod Honorable Mar 5, 2012 1 0 10,510 Mar 5, 2012 #1 Hello, i have ibm r40 laptop it has bga chipset problem, when presing keyboard it works then after same display problem, please help....
U unksol Splendid Sep 12, 2011 7,060 0 27,960 Mar 5, 2012 #2 assuming you mean the display only works when you put pressure on the keyboard the display cable is probably bad and it needs to be replaced, which requires opening up the laptop Upvote 0 Downvote
