Power supply advice
  • Power Supplies
  • Components
Last response: in Components
a b ) Power supply
July 1, 2011 7:15:55 PM
Hey there :hello:
I was doing some digging but havent been able to come across a definite answer - so thought of turning to you guys (who'd have more experience)
I'm thinking of making a totally passively cooled system - HTPC, web browsing and downloads. Came across the Seasonic X 460 Fanless PSU. Question is - i know I won't need more power than that. But can this PSU sustain a PC's load, running 24/7? :sweat:
* Specs are:
Core i3-2100
ECS H67H2-M
4GB Ram Kingston with AC RC pro coolers
2TB WD HDD + 320GB boot drive or a 80GB SSD
Lite-on DVD+/-RW
Thermalright HR 02
Transet case
Thanks for taking the time
More about : power supply advice
a c 298 ) Power supply
July 1, 2011 7:19:03 PM
You shoud never make a totally passive system, you need case fans at least to keep some air moving or everything will overheat, the X-460 relies on there being a positive pressure in the case to force some air through it, if you have no case fans it will overheat and shut down.
m
l
a b ) Power supply
July 1, 2011 7:24:12 PM
:S erm okay. What of the seasonic X-560? i was reading that it runs passively, and when it needs to cool down, the fan kicks in...and I'm going to go with this case : Antec NSK-3480 case
m
l
