Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Compaq P110 Monitor (Need help)
Forum Computer Peripherals : CRT Monitors - Compaq P110 Monitor (Need help)
Hello everyone. I need help with my new monitor. It says in the manual that the "most commonly" refresh rates are from 60-85Hz in every resolution. But i can change it to 100Hz in windows. I wounder if the monitor can be damaged if I use 100Hz. if anyone wants to read the manual and help me out here it is ftp://ftp.compaq.com/pub/supporti [...] 86-002.pdf
It is a 21" monitor.
/Christian
Sponsored Links
anyone feel like helping me? please?
Reply to swipe
- 0 +
Reply to swipe
- 0 +
I did go & read your manual. Your monitor doesn't support anything above 85 htz. Under Display Resolutions I only see 85 htz supported. If it's a new monitor I'd wonder why the manual was copy written in 1997?
You should see, like modern monitors, a best res. to run the monitor at. I don't see it with yours. For example I'm running a Viewsonic a90f + that I just bought. It says in it's manual optimum performance is 1280 x 1024 @ 75htz. Your manual says nothing like that.
I'd say you over amping that monitor @ 100 htz.. Best guess I've got after reading your manual.
Sorry it isn't the answer you wanted to here either.
I'm still learning & having fun doing it!! Trouble comes with the things you forget or overlook along the way that make it not so fun!!
Reply to RCPilot
There are 493 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
