I'm sure you've guessed by now I know virtually nothing about wireless.
Never had a use for it. I can wiggle through a wired setup but no idea what/if the difference is with wireless.
Not sure why I would need to change the IP but where I am I don't even need security. I'm in the middle of nowhere with nothing around for miles. I have the wired system secured but as far as the wireless, it would only be used for maybe an hour or two and intermittantly at that. Then it would get unplugged again and sit on a shelf until it's needed again.
I have it set at default and would assume that security would be pretty much non existent. IF I can get it to hook up I'd probably play with security but it's not really a necessity here.
I can give changing the IP a shot next time I have something here that has wireless. None of my machines do and it's usually laptops from visitors I need to hook up. And there's no problem if I just plug them into the wired switch or router.
Only have one laptop with wireless and it's traveling now. Even when it's here it gets wired in if we need it. But as I said, every machine that has been here can see the wireless. Just can't hook to it.
I was just wondering if the problem is trying to run it thru a switch. On the other hand, it shows as active and the machine shows on the lan. Like I said, doesn't matter if it can get to the lan, just need it to get internet access.
