Hi there,
My Phenom II 965 BE has been running fine (32 idle, 50ish under load).
But then I got that "genious" idea to to put in a new and even better heat sink. I yanked the old one off and of course the processor went with it. I then yanked the processor off the heat sink and bent like half the pins.
I spent half a day unbending pins with dental floss and a credit card.
To test it, I put the heatsink back on without reapplying new thermal paste. It worked fine. So I tried to get the heatsink back off but whatever thermal paste remained on the heatsink got glued to the processor AGAIN!! I decided not to push my luck and just left it all in there.
Now my processor is running about 35 idle and gets to about 55 on medium load but when video gaming on full eyefinity with 5760x1080 it goes as high as 65.
Should I try to remove the heatsink to add thermal paste or let it be? What is the best way to remove a heatsink off the badly damaged processor?
