G
Guest
Guest
Archived from groups: alt.games.vgaplanets4 (More info?)
I am currently frustrated by a battle that just took place over my
homeworld. One Bird Dark Wing equipped with a Super Laser attacked my
base. I (Stormers) had 17 Ill Winds equipped with PTTs and a standoff
range of 850, as well as 5 Deth Specs and some misc. ships.
The DW came in as a second wave, and some of my fighters immediately
started firing on him. Great, so far, so good. But my Ill Winds,
which started out hovering over my base slowly slid off to the far
upper right of the screen, while the DW slid in from the side toward my
base. One Deth Spec fired on it, but none of the other ships would
touch it.
My Alaska Refinery ship was floating there in the middle, and the DW
hit it with a weapon that (I'm assuming) killed the crew so it became
his. Immediately, the Ill Winds fired on the Alaska Refinery ship and
killed it, but still didn't touch the DW, just continued to move away.
Meanwhile, the DW starts to pummel my base with it's weapons for about
200 counts. Finally, a barage of shots from my Ill Winds takes it out
pretty easily.
I had all the ships set to 'Attack Enemy Ships' and 'Target Dangerous'
since I knew a couple of DWs were coming in for a desperate attack. I
also had upgraded my shields and Large Weapons through the exotic tech.
I'm frustrated that I lost quite a bit of my buildings, a TON of
natives, and some pop with so many ships against one! What the heck am
I doing wrong?
touch it.
pretty easily.
I doing wrong?
