Haf932 advanced how to connect 3.0usb to motherboard
Last response: in Components
July 3, 2011 10:29:57 AM
my system information:
Cooler Master HAF 932
EVGA X58 FTW3 132-GT-E768-TR LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATXd
Intel Core i7 975 Extreme Processor - 3.33GHz, LGA 1366
Cooler Master Hyper 212 Plus 120mm Sleeve CPU Cooler
CPU THERMPASTE|AS5-3.5G
Crucial RealSSD C300 - 2.5" 128GB SATA III (SSD)
HDD 1.5T|HITACHI HDS723015BLA642
EVGA 01G-P3-1563-A1 GeForce GTX 560 Ti Maximum Graphics Edition Video Card - 1GB
CARD AFT| PRO-55U 5.25" RT
SONY Black Blu-ray Burner SATA BWU-500S
WIN 7 ULT - 64-BIT
4Gx2|GSKILL F3-12800 ddr3
RX850watts
i would like to know if there is an adapter to connect the cable from the usb 3.0 in the front of the case to the motherboard thanks in advance.
a b ) Power supply
July 3, 2011 10:53:19 AM
Yes, it should of come with your case.
m
l
July 3, 2011 7:01:03 PM
I am having a hard time fully grasping the question, but ill guess that the HAF 932 advanced uses an internal connector for the cable and your motherboard does not have an internal header.
So you want an adapter to go from the header cable on the case and route out the back and into one of those ports? I doubt there is one, sorry.
m
l
a c 87 ) Power supply
July 3, 2011 8:07:19 PM
Divert the USB 3 cables from the HAF 932 out of the case through the rubber grommet holes at the back of the case. Then plug these cables into the USB 3 ports in the rear.
m
l
a b ) Power supply
July 3, 2011 8:20:57 PM
Looking at the 932 on coolermaters website it looks like they've revised thier panel so that it now connects to an internal header. I'm off to order one. LOL
m
l
July 3, 2011 8:43:55 PM
I have the old version of the HAF 932. And the X-58 Classified EVGA board. I had to install a USB 3.0 host card just to get USB ports at the rear.
I will look at the new HAF 932 (I wish they would use a new designation in order to avaoid confusion with the old version).
m
l
July 3, 2011 8:45:46 PM
They did use a new designation - the HAF Advanced!
m
l
July 4, 2011 10:01:08 AM
popatim said:
The HAF comes with a cable designed to pass thru to the rear USB3 port but its usually not long enough to do so. If your motherbd has a USB3 header you can use the UC-01
http://www.frozencpu.com/products/12740/cpa-570/Lian_Li...
the cable is just like that plug what I need is the female so i can connect the male thanks it was close though.
m
l
July 4, 2011 10:02:38 AM
this one is a male like the one in haf932 advance im looking for a female to connect the male. thanks
m
l
a b ) Power supply
July 4, 2011 8:03:57 PM
For those interested, Coolermaster wants $15.99 for the Front panel USB3 (2 port) adapter. Its just a 3.5" adapter. Its another $5 for the 5.25" matching mesh plate. I figure for $20 its not worth it since you can get a multicard reader with usb3 for about the same price.
http://cmstore.coolermaster-usa.com/product_info.php?pr...
or you can buy it as a package for $20 but the plate isn't the same.
m
l
July 4, 2011 8:14:12 PM
The problem with multi card readers is that they need USB pin headers on the motherboard. My old style HAF 932 used up the motherboard USB 2.0 pin headers for the front panel USB. So I had to buy some special USB cables, plug them into the card reader cables (2) and then route them to the back of the case and plug them into 2 USB 2.0 ports. Rather expensive solution.
This is what I used: http://www.performance-pcs.com/catalog/index.php?main_p...
m
l
July 31, 2011 10:30:14 PM
@serkenshin
Hey I am running the same i7 cpu as you with the same cpu cooler (single fan). Can I ask what CPU temps you are recording?
I just switched out from stock cpu cooler (44c @ idle) to the above mentioned fan (cores running @ 40-44c @ idle). I used artic silver 5 using the dot method for thermal paste application.
I thought I was suppose to see cooler performance.
My System Information:
Cooler Master Elite 430 Black
Intel Core i7-975 Extreme Edition Bloomfield 3.33GHz
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
HITACHI 2TB 7200 RPM 32MB Cache SATA 3.0Gb/s
Palit GeForce GTX 460 (Fermi) 768MB
Corsair DDR3 4Gb 1333mhz RAM
ASUS Black 4X BD-ROM 8X DVD-ROM 32X CD-ROM SATA Internal Blu-ray Drive
ASUS 24X DVD Burner
Antec EarthWatts EA650 650W ATX12V Ver.2.2 Power Supply
5 total Cooler Master System Fans
Sony MRW620/U1/181 17-in-1 USB 2.0 Card Reader/Writer
Windows 7 Professional 64-bit
m
l
August 1, 2011 12:44:46 AM
sundevilchemist said:
@serkenshin
ASUS 24X DVD Burner
ok i got about 27c @ idle with 2 fans on cpu now and the problem i resolved with an adapter internal 3.0 adapter
m
l
August 1, 2011 1:04:05 AM
There must be something wrong with my cpu cooler than. I just tested it again and am at 40C idle and 64-68C @100% load.
My abmient temp is 26C (79F). I think I should be in the low 30's at idle.
Thanks for your reply.
m
l
