Problems with device management/LAN
I have a km400-m2 mobo with a clear usb modem attached. I am trying use ICS to connect that through my router to other computers wirelessly, but my LAN/ethernet cable, though plugged in with lights showing power, is not recognized in device manager. The WIMAX shows up, but there is no ethernet/LAN. I have tried using uniblue driver scan 2011, but it did not find anything to update. Any ideas? Is the LAN blocked on this mobo?
3 answers Last reply
More about problems device management
  1. Have you installed the LAN drivers?
    Check which motherboard version you have:
    1.0 driver
    3.0 driver
  2. ok, so I downloaded the file, but how do I install the driver? I have tried this b4 but I keep hitting a dead end here.
  3. You have to extract the file (with something like winrar)
    Save it to somewhere on your hard drive (Desktop is easiest to find)
    - Go to where you save it and find a folder that says VIA823x_40 and open it
    Then open the second file which might be different for you but since i am Using windows 7, it says vista for me
    -Then depending on if you have 32bit (open the X86 sub-folder) or 64bit (open the X64 sub-folder) operating system
    -double click the file that has "setup" in it
    If you don't know what version you have then:
    -go to start menu (windows key)
    open "run"
    type "dxdiag" press enter
    look at the list next to "operating system:"
    If the first set of instructions are too complicated, then just tell me your operating system and if it is 32bit or 64bit and i'll upload the specific folder.
Prebuilt LAN Ethernet Card Systems
