Hey folks,
I think I've gotten together a decent set of components for my first-time build. Just have a few questions to run by you experts!
Approx. Purchase Date: ASAP, likely by the end of next week if possible.
Budget Range: Max, about $1300 after rebates, but there's a little wiggle room.
System Usage from Most to Least Important: Mainly gaming, nothing else taxing: multitasking, streaming HD, etc.
Parts Not Required: Speakers, keyboard, mouse, monitor
Preferred Website(s) for Parts: None, but I've mostly been using Microcenter (there's one very nearby to me) and Newegg.
Country of Origin: USA
Parts Preferences: SB CPU, otherwise none.
Overclocking: Probably if I can find some good guides, but no big OC'ing.
SLI or Crossfire: No; potentially down the road though.
Monitor Resolution: 1920x1080
Parts so far:
LG Black 24X DVD+R 8X DVD+RW 16X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM SATA DVD Burner - Bulk - OEM
Antec Nine Hundred Two V3 Black Steel ATX Mid Tower Computer Case
Barracuda 7200.9 500GB 7,200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive ST3500641AS-RK
http://www.microcenter.com/single_product_results.phtml...
Onyx Series OCZSSD2-1ONX64G 64GB SATA 3.0Gb/s Internal Solid State Drive (SSD)
MSI R6950-2PM2D2GD5 Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Core i5 2500K LGA 1155 Boxed Processor
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMZ8GX3M2A1866C9
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
GIGABYTE GA-P67A-UD3P-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
All of which adds up to about $1150 before taxes and shipping.
So, as for my remaining questions:
I'm completely lost when it comes to PSUs, and so went by some of the tools and guides I found on here. Is the one I have picked out sufficient for my needs and for some light OC'ing? I assume it wouldn't be sufficient if somewhere down the line I wanted to add another graphics card; what about (see below) unlocking the 6950, how would that change my power reqs?
How about the case - it's not overkill, is it? I thought about the Antec 300 as well.
Once I have the thing constructed, does anyone have any comments on how difficult it would be to OC the 2500k just a little bit? It's something I want to do if it's easy and possible, but I want to make sure I know what I'm doing. Along those same lines, is a separate cooler necessary if I'm not going far above baseline?
Similarly to the OC'ing issue, how about unlocking the 6950 to a 6970 - comments or thoughts on doing that?
This is my first effort, so don't be too harsh!
Thanks!
