What is distilled water to 90% alcohol ratio for screen cleaner?
what is distilled water to 90% alcohol ratio for screen cleaner? :o
3 answers Last reply
More about what distilled water alcohol ratio screen cleaner
  1. 50% distilled water 50% alcohol.
    Don't use paper towel.
    Don't spray the solution directly on the display screen.
    Moisten a microfiber cloth with the cleaning solution and wipe down the display screen.
    Thanks
  3. +1 50/50. the alcohol should be isopropyl alcohol. You may find it leaves a residue. This can be removed by just dampening the cloth with water - no alcohol and just wiping over with that.
Power Supplies Components
