Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > [Solved] Will XFX Radeon HD 5830 work on my 500 Watt power supply?
Forum Graphics & Displays : AMD Radeon [Solved] Will XFX Radeon HD 5830 work on my 500 Watt power supply?
Best answer from Helltech.
I'm not too keen on computer hardware and I had been considering buying a new graphics card. I was really interested in the XFX Radeon HD 5830 and was wondering if it would work on my pc. Any feedback would be greatly appreciated.
My Specs:
Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33 GHz
DDR2 4 GB RAM
500 Watt Power Supply
The card I'm looking at buying:
http://www.tigerdirect.com/applica [...] CatId=3669
My power supply:
http://www.newegg.com/Product/Prod [...] 6817154026
My Motherboard (not sure if this is relevant):
http://www.newegg.com/Product/Prod [...] -_-Product
Reply to pineappleking
Best answer
Spend a little more money and get a decent power supply in my opinion, that is the one and only part in your computer you should spend a little extra cash on. However, yes 500w would be enough for a 5830.
Like this.
http://www.newegg.com/Product/Prod [...] 6817371035
Also, if you do not mind rebates, this card is only ten dollars more and is quite a nice bit better.
Message edited by Helltech on 01-28-2011 at 10:38:37 PM
------------------------------ |CPU| i7 920 @ 3.8Ghz |MOBO| Rampage II |RAM| 12GB, 6*2Gig GSkill DDR3 |GPU| EVGA GTX 260 x2 SLI
|HDD| 300GB VelociRaptor + 2*1TB Caviar |Sound| X-Fi Titanium Fatal1ty |PSU| Corsair 750TX
|Case| XCLIO A380BK |CPUCooling| Zalman CNPS 9000 |OS| Vista 64
Reply to Helltech
Thanks for the reply, I really appreciate it. I looked at that graphics card you suggested, would that for sure work with the power supply I have? If so, I'll definitely purchase it.
Yes what he suggested will work and it will last much much longer than the off brand you were looking at.
------------------------------ Phenom 2 940 @3.5ghz|Arctic Freezer 64 Pro|Win 7 64 bit|GIGABYTE GA-MA790GP-DS4H |OCZ Platinum 4GB DDR2-1066|Asus 6850 Direct-cu Crossfire|Corsair TX750|Antec 300|G-skill 64gb ssd|WD black 750gb|Blue-ray dvd player|
Reply to xx12amanxx
It would work with the powersupply I suggested. I have no idea if it will work on your generic one. Kind of taking a shot in the dark there. You have enough watts and amps to run it, but the quality of that PSU is unkown and anything can happen.
Message edited by Helltech on 01-28-2011 at 10:53:09 PM
Reply to Helltech
Thanks a ton! If I have any problem with the card I'll take a look at that power supply you mentioned.
If you want an objective review of your power supply jonnyGURU.com has one:
http://www.jonnyguru.com/modules.p [...] ry&reid=65
Reply to ko888
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1561 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 2 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
