Hello All
It is time for me to make a delegated decision on which micro ATX case I will use in my next build, I have decided I am going to try to cram as much power into a small case as possible so cooling is an issue. Luckily I have narrowed it down to 3 cases which will not only do the job but are full of great features as well.
The build will consist of i5/i7 at stock settings and one of the latest high end video cards (all these cases cater for extra long video cards) I prefer to have one very powerful card to two weaker ones.
So here are the runners up, well start with the more adventurous and work down to the more standardised desktop case.
1) The SilverStone Fortress FT03
Like the good cooling flow (the heat rising up from the bottom) , small footprint, a bit more funky with its weird design looks fantastic, but it will not fit in my current desk.
Read about it here - http://www.silverstonetek.com/product.php?pid=291&area=usa
2) The SilverStone Temjin TJ08
Like the big fan at the front, separate PSU holder, once again from SilverStone a very good cooling case, more typical style as well, but do not like the upside-down motherboard idea (hot on graphics card, unless someone can tell me its better?)
Read about it here - http://www.silverstonetek.com/product.php?pid=303&area=usa
3) The Lian Li PC-A04
Like the very high build quality, dual 120 mm fans, customisable hard drive holders, once again more typical styled case nice look to it, has a top 120mm exhaust fan but the airflow is less directional and only one USB 3.0 port
Read about it here - http://www.lian-li.com/v2/en/product/product06.php?pr_index=561&cl_index=1&sc_index=25&ss_index=63&g=f
Well! hopefully someone can help me out, please add your thoughts on the matter, Its hard to decide as all of them fit my needs perfectly, I am just looking for anything that might cause trouble with a particular case design so I can rule one or two out.
Thanks in advance - hjn123
