Technical problem: I can not read my rst-files. Can anybod..
G
Guest
Guest
Archived from groups: alt.games.vgaplanets4 (More info?)
Hi !
I have a registered version (checked)
I have downloaded plain rst-files (after getting into these problems)
I have installed another planets (v4beta19,host193,p059,latest vcr)
I have put all my rst files in the appropriate war/slotx/ directories
(I had them I a user/Game/ directory before)
I am playing 4 games, all above 10th turn. No problems before !
I downloaded 3 different rst-files but could not open them. (error
mistakes see below)
I could still manipulate a running turn and save it, but building a
turn created error mistakes.
Error mistakes:
1) UnzipRST Error 2
File: ...\WAR\SLOTx\ETAx.rst
(x represents a slotnumber and playernumber.)
2) Can not read compressed RST-File.
Some more windows with messages and then planets is gone
Any idea before I start looking for a spare pc to install planets ?
Thanks
Andreas
G
Guest
Guest
Make a directory named c:\temp\ on your computer.
G
Guest
Guest
Thanks Tim.
There was a different file in c:\ called temp blocking the creation of
a temp folder due to identical names.
I removed it and problem was solved.
I even do not have to create c:\temp\
Appologies: Some older postings covered this problem at least partially.
