Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > My dvd drive doesn't work on the same rail as my graphic card but will
Forum CPU & Components : Power Supplies, Cases & Mods My dvd drive doesn't work on the same rail as my graphic card but will
I just found out that my dvd drive doesn't work on the same rail as my graphic card, when I plugged it into the spare connection that was available alongside my HDD it worked fine along with my graphic card. Now I wanted to ask can I add another HDD into the SATA power socket that was earlier failing to power my DVD Drive or will my HDD also not work? My DVD Drive would work with no trouble if I took out the graphic card.
Reply to dhruv990
How did you plug in the DVD player into the same rail? Unless you spliced the wires...
Reply to Randomacts
Just 2 questions here.
1. What video card do you have?
2. What power supply do you have (specs/wattage, and brand)?
Reply to IH8U
Most probably that rail does not have sufficient power to power both VGA and DVD drive.
But to be sure as IH8U asked please state the exact components you are using like PSU / VGA / DVD.
------------------------------ AMD Phenom X4 955BE@3,8Ghz | CM Hyper 212+ | 6Gb ram | Asus M4A79XTD EVO/USB3 | CM Real Power 550 | XFX 6850BE | CM Centurion 5 II | Logitech Z-5500 | Logitech MX-518 | 2x 160Gb WD BE | 1x 1Tb WD BE | Plextor PX-L890SA |
Reply to soest009
I'm using an Indian Brand PSU, don't remember which exactly. Lite-on DVD Writer with lightscribe, and a Zotac 9500 GT 1 GB DDR2. I don't know how they both used the same rails, However I had posted a question about the dvd writer not working with the graphics card and someone suggested that they both are being powered by the same rail. So I just changed the power cord and now my HDD and The DVD are being powered by the same set of wires(came prespliced)
Reply to dhruv990
Your not making any sense. You video card is powered by the motherboard, you don't plug it into anything else.
Message quoted 2 times
Message edited by geekapproved on 07-06-2011 at 06:44:03 PM
------------------------------ Core i3-2100/Asrock H61/8GB1333/XFX HD5850oc/WD Black 500/Antec 300/Antec EA380w bronze
Currently playing Deus Ex:HR a second time on Hardcore
Reply to geekapproved
Even I'm confused, all I know is that my PSU is some weird brand that does weird things. With the old cable power cable that I had plugged into the dvd drive, the dvd drive would not work as long as the graphics card was installed. As soon as I removed it the dvd drive worked. Now I realised I had a spare SATA power connector lying around(it's supposedly coming out from the same set of wires that has another sata power cable that's plugged into my hard drive) by plugging this spare cable into my dvd drive, my dvd drive works fine even though my graphics card is installed.
Reply to dhruv990
So you had a bad cable. Glad you were able to figure it out.
Whoever told you it has something to do with psu rails, is a complete idiot.
Message quoted 1 times
Message edited by geekapproved on 07-06-2011 at 11:36:54 PM
Well higher end graphics cards require extra PCI power... but those plugs would never fit into a DVD drive
Reply to Randomacts
If it was a bad cable it shouldn't have worked when I plugged out the graphic card.
Reply to dhruv990
And slightly older video cards made use of molex connectors to power the video cards, i expected that was the case.
Reply to soest009
A 9500GT does not require ANY power connector.
You said you changed the power cable to the dvd drive and it worked.
Sorry I forgot to add "with the old cable" to "My DVD Drive would work with no trouble if I took out the graphic card" in the opening post.
Reply to dhruv990
The information about the type of video card was not available to me when i posted it.
Just after my post he mentioned the type of video card he is using ;)
On a side note there are 9500GT cards that require external power which are delivered with a 6pin to molex converter cables.
Message edited by soest009 on 07-08-2011 at 11:43:01 AM
Reply to soest009
There are 1619 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 2 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
