I'm Building a AMD System check it out
Cyphen19823
Hey my names tony im new here and im building my first custom built computer with my buddy. im spending a total of $1400 on the computer
But here is what i got so far:
Cooler master HAF X
AMD 1100t
Western digital caviar black 1tb HD
Corsair H50
Patriot 2 sector 5(8 Gigs worth)
coolermaster 1000w power supply
EVGA 570HD SuperClocked Graphics card
Asus IV Mother board
NZXT LE Touch screen fan controler
DVD Multi drive
G515 keyboard
Running on windows 7 64x bit im hoping to O.C this computer to 4.2GHZ
What do you guys think of this build?
JoeAdamsIV
127
It's good.
If your gaming I would recommend:
965 BE
HDD is fine
Cooler is fine
RAM is fine
1000W is quite a bit, 850W Gold should do the trick
GPU is fine
Motherboard is fine
Controller is fine
DVD Drive is fine
Keyboard is fine.
Enjoy your build.
g048989h
280
If youre OC'ing plan to buy an aftermarket CPU cooler. something similar to a CM Hyper 212 or a Notua NH-D14. also, nothing wrong with going over the top on the PSU, but 1K is more than you currently need. A good 850 would be more than enough and might save you a few bucks for a good CPU cooler
