AMD Build. Need some help.
Last response: in Systems
Approximate Purchase Date: April 4th/5th
Budget Range: Under $1000
System Usage from Most to Least Important: Gaming (Mount & Blade Warband and Neverwinter Nights 2), Anime
Parts Not Required: Keyboard, Mouse, OS, DVD drive
Preferred Website(s) for Parts: www.newegg.com
Country of Origin: USA
Parts Preferences: AMD, Sapphire
Overclocking: Yes
SLI or Crossfire: Later on yes.
Monitor Resolution: 1920 x 1080
Additional Comments: Here are the parts I have picked out, and also this build is for myself, the last two have been for others.
Case: Coolermaster Storm Scout $69.99
CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz $139.99
Mobo: ASRock 890GX PRO3 AM3 $104.99 + $7.87 Shipping
RAM: G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 $45.99
HDD: Western Digital Caviar Black 1TB 7200 RPM 32MB Cache $77.99
PSU: Antec TruePower 650W $69.99 (Unless someone has a better PSU I should get)
GPU: ??? Not sure yet, must have HDMI.
Monitor: Split between two, unless theres a better monitor at the same price that has HDMI
Overclocking: Yes
More about : amd build
Hello Coel;
Good job picking parts and deals
ASRock 870 EXTREME3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard $110 & free shipping This board does CFX @ x8/x8
It's less expensive than the ASRock 890GX PRO3 $105 & $7.87 shipping. This board does CFX @ x16/x4 and not the preferred x8/x8.
You haven't picked a CPU cooler yet. CORSAIR CAFA70 120mm Dual-Fan CPU Cooler $31 a/r
Corsair A70 Dual 120mm Fan CPU Cooler Review
A better deal on a 650W PSU: XFX XXX 650W 80+ BRONZE Modular PSU $59 a/r & free shipping
XFX XXX 650W PSU review
Thats a very good price on the WD Caviar Black HDD but even with the discount I'm not sure it's worth $8 more than the Seagate Barracuda 7200.12.
Either one will be a great choice.
Between the monitors you listed: VH238H has better customer feedback reviews over @ NewEgg.
Can you squeeze a HD 6950 into your budget?
Related ressources
- New Amd build . Need Help with components - Forum
- Need some help amd or intel build - Forum
- Need help with new AMD build ! Advise needed! - Forum
- Need help with AMD Build . - Forum
- $600.00 Build AMD Build - Need help choosing rest of the parts - Forum
The HD 6790 is suppose to overclock pretty nice, ones on Newegg right now its Powercolor. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
But I might hold off on the video card till more 6790s come out.
Clearly says AM3+
http://www.asrock.com/mb/photo/Box/890GX%20Pro3%28m%29....
Clearly says AM3+
Says it supports AM3+ CPU here -but doesn't claim to be a AM3+ board.
http://www.asrock.com/download/e-catalog/890GX%20Pro3.p...
It's good for 8 core CPU support.
Still trying to figure if that is a good choice overall though. From what we know it's more important to have GPU upgrade options than to have CPU upgrade options.
The CFX @ x16/x4 is not a complete downcheck - it's just less than ideal for CFX.
I don't suppose you're in a position to wait a few months and get a 990 board?
OK,
It's probably a good idea to hop over into the Motherboards section of the forums and ask the experts there if there are any hidden issues with AM3+ CPUs in the 890/870 motherboards revised to support them like that 890GX Pro3.
While the HD 6970 is a great price I'm thinking you'll REALLY want to CFX that build sooner, almost right away, with a 1920x1080 monitor.
It might overclock REALLY well - but it's still in the GT 550 class of GPU.
I guess we'll know tomorrow when the 6970 NDA comes off and the reviews pop up
Best solution
CM SickleFlow 120mm Red LED case fan
If you want a Red LED fan on the CPU cooler this fan would work great. A higher CFM airflow and quieter operation too.
Will the 6850 fit in my case?
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
I've decided on it over the 6790.
It's built on the 6870 PCB so there are some limits to what they can do.
Other 6790s:
HIS (left) XFX (centre) and Sapphire (right)
Other 6790s:
Related ressources:
- ForumNeed help with AMD Build
- ForumAMD /INTEL Build : Need Review
- ForumNew amd build need some help
- ForumNeed help with an AMD build
- ForumPossible Build GAMING AMD BASED ( Help Needed)
- Forum$500 Budget AMD Gaming Build - Need help
- ForumNeed AMD mini ITX for Bitfenix prodigy build
- ForumNeed help deciding between an AMD and Intel Build
- Forum$500-$700 AMD gaming build . Need some help !
- ForumNeed Help with ~800 AMD Build
- ForumHelp Building $700 Gaming PC
- More resources
