Closed Solved
Is this mobo compatible with my parts?
I have a GA-MA790X-UD4P motherboard atm, and am looking to upgrade to a GA-970-UD3 board, and was wanting to know if my CPU was compatible, it is an AMD Athlon II X4 620 Processor, I also got Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 996659B, for it, and I think it's compatible.
Just wanted to get an A-OK from the vets here before i forked out 100 bucks.
I can submit a CPUID report if needed, just didn't want to spam this thread in case it was unnecessary. Thanks!
4 answers Last reply Best Answer
More about mobo compatible parts
  1. Best answer
    The CPU is compatible with your new mobo http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=3907
    All the parts are compatible.
  2. Thanks so much!
  3. Best answer selected by shazamknight.
  4. This topic has been closed by Nikorr
Motherboards Compatibility
