Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > Anything I can do with these spare parts?
Forum Systems : Homebuilt Anything I can do with these spare parts?
I have a Dell XPS m1710 laptop with a fried vid card and I was wondering If there was anything I can take from it for my new desktop computer I recently built. Idk if it matters but my desktop's mobo is a MSI P67A-GD65. I figure their prolly isnt anything I can use (except the hdd, got that) but thought I would ask. And for the parts I can't use that are worth something is ebay my best option?
Not really. Different RAM slots, different CPU socket, basically not much that's going to be compatible. The hard drive you can get to work, but I don't know why you'd want to use a 5-year-old 100GB drive on a new machine, even just as a data drive. It's likely to die well before your main drive (which I assume is new) anyway, and I generally don't see it doing anything except causing you trouble. 100GB of hard drive space is worth about $5-$7 these days; if you're that hard up for space, you're better off just getting a bigger HDD for your new machine in the first place.
Reply to capt_taco
I already put the hdd in my new comp and have it running ubuntu (its a 200GB 7200rpm SATA, so decent enough). I have a 1TB as my main and a 750gb external drive so I'm good on space. I figured nothing would work... There was one thing I was wanting to try though, it has a sd card slot and my desktop does not. I didnt realize how much I use sd cards till the XPS broke. So would there be anyway to connect the sd card slot to my desktop mobo? (idk if the card slot is part of the mobo in laptop, if thats the case, im guessing no)
Message edited by harry286 on 04-06-2011 at 06:35:38 AM
Reply to harry286
it won't work in the desktop, but as usb card reader is cheap, as is one that would go in a 3.5" slot that used to be for floppies.
this is a usb one for only $7:
http://www.newegg.com/Product/Prod [...] 6820137006
------------------------------ We have no wish to offend you, unless you're a twit.
My PC: I5-2400, ASRock H61-VS, Mushkin 4 GB 1333, HD 6850, 2x Seagate 500 GB HDD, Corsair 430W, Rosewill R102 case
HTPC: Phenom I 9650 2.3Ghz, 4 GB DDR2-800, 120gb hdd, HD4850 512MB, Ultra 500W
Reply to ScrewySqrl
Nope. If the GPU is on an MXM card (it might be on an XPS but don't know for sure) you could get another one off ebay and replace it. If it's soldered on to the motherboard though, you will have to replace the motherboard with a compatible one which involves some effort to find ant alot of effort to replace.
------------------------------ Play Brutal Legend Phenom II X4 955 @3.6GHz | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A | Lite-On BluRay | CF Gigabyte UD 5870x2 | WD 1TB Black| Corsair 950TX | APEVIA X-Dreamer Black | Win XP 64 & Win 7 Pro 64
Reply to megamanx00
I looked into getting a new video card for it (geforce go 7950 gtx i believe). But they are very expensive... I would have to find a very cheap one to make it feasible...
Reply to harry286
There are 1543 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 3 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
