Closed
Two 6 pin power connectors.. for GPU GTX 560Ti
  • Power Supplies
  • Gtx
  • GPUs
  • Power
  • Components
Last response: in Components
July 8, 2011 9:37:54 AM
Thus, this 6pin power connectors comes w/ the psu when you buy 1? what does it looks like. and seems i can't find it. do i need to buy new psu? or just need to buy power connectors, or i can use my gtx 560 w/o it. or /w just 1one 6pin power connectors.
More about : pin power connectors gpu gtx 560ti
Best solution
a b ) Power supply
July 8, 2011 9:57:08 AM
if your PSU enough support for GTX 560 (usully this VGA include cable Connector PCIE ..??? )
just buy cables like this :
July 8, 2011 10:46:21 AM
ohh tnx..
Score
July 8, 2011 10:46:33 AM
Best answer selected by roan1234321.
Score
a c 94 ) Power supply
July 8, 2011 11:56:09 AM
You need to make sure your PSU can support it. If not it can explode, taking who knows what with it when it does.
Score
January 17, 2012 10:35:42 AM
there are 2 ports with 6 pins on the gtx 560 right ?
but the card came along with only one such provided,..the same above wire
do i need to get an extra such and plug both the ones to the card to the psu?
and i dont think my psu has 4 free 4pin connections available
only 2 4-pin connection available,...i mean only one such 6pin to 2x4pin can be connected
mine is a 500 w suplly and not a popular brand
Score
