I've checked this thread and looked through it.
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-boot-video-problems.
Over the past month or so like 3-4 episodes (lasting a few hours of me trouble shooting) of my computer will sometimes not post at all. No monitor output when I turn it on, all fans on sounds like it's fine. Can't get into BIOS. I will have to do a variety of things and I cannot pinpoint what component is causing the failure.
I have tried
1)checked memtest+86 on my RAM for 5 passes and it's been fine.
2)checked my overclock, it's stable at a very modest 3.6-3.8ghz at 1.4v. Prime95 is fine running for 6 hours+
3)removed RAM and it gives me LONG-SHORT-SHORT complaining about lack of memory which is good. but doesn't necessarily post after I put them back in to make it stop complaining.
4)removed video card and it gave me two varying results in different episodes. Once it beeped a code evidently complaining about my removal of the card. The most recent one I booted without it at all and it didn't post, nada.
5)cleared the CMOS/BIOS. Both using jumper and then removing the battery and waiting 30 minutes+
6)checked PSU voltages from HWMonitor and it seems to be delivering right amount of voltage accurately.
Vague possibility that:
"For troubleshooting purposes, disconnect the reset switch. If it's shorted, the machine either will not POST at all, or it will endlessly reboot."
Each of these episodes I am able to eventually get it able to boot but I am unable to narrow it down to a component (RAM or videocard, and right now since I have no idea, I'm open to the idea that this is a possible this is a mobo problem).
My question is, what could be the cause of this problem based on what I have done & how my system has been able to bootup and only intermittently has this problem, have it solved by me just plugging things in and out kind of at random, and only for it to crop up again out of the blue?
KEY HINT: My board AFTER it posts I see some messages that it outputs and I notice it gives me an overclocking failed! message and I didn't even change any paramaters! It did this BEFORE I overclocked my system so I'm pretty sure my modest overclock is not causing this. I've researched this on google and other people run into the same problem. Either my ASUS board is trying to run some dumb overclock-utility/feature before I can even input anything sometimes or something ELSE is causing it to display that message.
This is frustrating!
Oh my system is
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808&cm_re=955-_-19-103-808-_-Product
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
CoolerMaster Elite 430
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
OCZ StealthXstream II OCZ600SXS2 600W ATX12V v2.2/ EPS12V 80 PLUS Certified Power Supply
http://www.newegg.com/Product/Product.aspx?Item=17-341-039&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=(keywords)&Page=1#scrollFullInfo
SAMSUNG Spinpoint F4 HD322GJ/U 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=22-152-244&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=(keywords)&Page=1#scrollFullInfo
ASUS M4A77TD AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131603
HIS H585FN1GD Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=14-161-330&SortField=0&SummaryType=0&Pagesize=25&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
I have tried
Oh my system is
