Closed Solved
ASRock z68 Professional Gen 3 Cha_Fan1 control problem
Hello All!
I'm having a small problem with my ASRock z68 Professional Gen 3 mother board.
Did anybody else have a problem controlling Chassis Fan 1 (Cha_Fan1) in the UEFI?
All of my fans' speed can be controlled except for the Cha_Fan1. No matter what I set in the UEFI - it spins at max speed.
The mobo is in the Cooler Master HAF 932 Advanced case. I'm plugging in the side fan that only requires 3 pins but the Cha_Fan1 has 4 pins. Could that be an issue?
Thank you!
3 answers Last reply Best Answer
More about asrock professional cha_fan1 control problem
  1. Best answer
    yeah you need 4 pins on the fan for it to work correctly. The 4th wire is pwm which controls the speed. You can buy a fan controller http://www.newegg.com/Product/Product.aspx?Item=N82E16811995073 to be able too control the speed.
  2. Best answer selected by timurich.
  3. This topic has been closed by Nikorr
ASrock Fan Motherboards Product
