Hammer and prybar?
If you have no idea what the name or model number is its real hard to give specific advise, but one common way that front panels are held on is by little plastic clips that stick into the case, open up both sides of the case and you may be able to see 4-8 little plastic wedges sticking through the metal support of the case and holding the front panel on.
