Sign-in / Sign-up
Wireless adapter problem!!!
  • Homebuilt
  • Windows XP
  • CD-Rom
  • Wireless Adapter
  • Systems
  • Product
Last response: in Systems
a b B Homebuilt system
April 6, 2011 10:27:34 PM
Hi I bought this wireless adapter for my windows xp 32 bit
However, using the CD that came with it to install it wont detect any networks. I was told to use ralink so i downloaded the (RT256x/RT266x) file and it still wont work. I was wondering what else i can do or what the problem is.
Thanks
More about : wireless adapter problem
April 6, 2011 10:34:24 PM
Your link is broken. Can you fix it? Then we can help you out.
m
l
April 6, 2011 10:48:59 PM
fixed :lol:
m
l
April 6, 2011 10:58:35 PM
OK, it looks like you have the correct driver and I assume you have it installed correctly (the antenna is attached, right?? :lol:  )
Are you using Ralink's connection software or the Windows built-in wireless connection utility?
m
l
April 6, 2011 11:06:16 PM
they antenna is connected. However, when i click on network adapters under hardware devices, i dont see the adapter. Also i think i chose zero connection.
m
l
April 6, 2011 11:09:40 PM
Zero configuration is the Windows utility, so you're good there.
If the wireless card isn't showing up in device manager, then either the driver is not installed properly or the card is not seated properly. Maybe try a different PCI slot?
m
l
April 6, 2011 11:32:16 PM
hmm. i switched to another PCI slot but its still not showing. With my other wireless adapter, under device manager > network adapters, there were 2 things: Linksys and Realtek.. Now it only shows Realtek. I think i put the card in correctly, but it still wont show. what else can i do? :cry:
edit: also, does it matter if i download the (RT256x/RT266x) on to a USB and install it that way or do i need to download the file directly to the computer i want the wireless adapter on?
m
l
