Getting ready to pull the trigger on this i5-2500k combo: http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.627552 $520
I already have two of these 460's I got a nice deal on: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127551 $290
And also going to use this case instead of the one in the combo: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066&cm_re=antec_three_hundred_case-_-11-129-066-_-Product
Now I'm pretty sure the PSU in that combo isn't enough for the two 460's and even if it is I don't trust a "rosefail" running that much $$ looking at this PSU instead: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021 Antec TruePower TP-650 650W $70
I will use the case and PSU in the combo in another build so I don't mind the extra parts. The case was only 5 bucks more than the one in the combo and the antec PSU is only 10 more putting the total cost for the build right around $825.
Want to know if that Antec PSU is going to be enough for the build and if there would be a better build option for around $825.
Thanks!
Edit: This is a gaming build for 1920x1200 res
Thanks!
