I ordered all my parts and pretty much everything is connected and running. The problem is that I have the HAF 932 advanced case and it comes with the USB 3 ports and cable. I also have the Asus p8h67 m pro but i cant seem to figure out where to connect the cable on the mobo or if its even an option. If theres some kind of converter or something so I can actually connect the cable it would be great because I dont want to have the 2 USB 3 ports just for show. Also, the case came with a 1394 cable which looks like it should belongwhere i connected the other usb's but I wasn't sure so I left it disconnected.
Here are the two parts:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131711&cm_re=asus_m_pro-_-13-131-711-_-Product
