Help choosing components
Hi I want to build my first pc. I have no idea what components to purchase. I would like an intel cpu and motherboard. I would prefer at least 4gb or more of ram.The motherboard must have two pic-e slots because i would like to do a crossfire setup in a few years time. I already bought a sapphire HD6950 graphic card so the motherboard must support at least 2 graphic card with 1 pci e slot must be at the speed of x16 and the other does not matter but the higher the better. Must have 1tb hard drive. I want a case that has a windowed side panel that is not too expensive around $120. I would also need a cpu cooler that will fit in the case you suggest.
I would also need a power supply for one graphic card for the meantime. I was thinking of a Vantec ion2+ 600w .Do you know how many pci-e power connectors this psu have and is 600w enough for 1 gpu?
Is there anything else that i am missing?
4 answers Last reply
More about help choosing components
  1. Fill out the form in the sticky, link in my sig.
    Your country and budget range are especially important.
    In general the 2 1155 xfire choices atm are the Asus p8p67 Pro, or GA p67A UD4 both right @ $190 in US.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131703&cm_re=asus_1155-_-13-131-703-_-Product
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128478&cm_re=ga_1155-_-13-128-478-_-Product
    HD spinpoint F3 or 7200.12 are great buys.
    Case HAF 922, CM 690II are general suggestions.
    HSF wise, CM hyper 212 plus, scythe mugen are good for $30-$40
    PSU, go with a good company. So Antec, Seasonic, XFX, Corsair are you best bets.
    This xfx 750W is one of the best buys in the US at $110
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207003&Tpk=xfx%20750
  2. Budget Range: $600
    System Usage from Most to Least Important: mainly for gaming, surfing the internet and watching movies
    Parts Not Required: Monitor, mouse, Keyboard
    Preferred Website(s) for Parts: Wootware.co.za , Rebeltech.co.za , Newegg.com
    Country of Origin: Australia
    Parts Preferences: I would like to use an Intel CPU & asus mobo and g.silk for ram
    Overclocking: Maybe
    SLI or Crossfire: Maybe
    Additional Comments: Would like 4gb of ram, need a 600w power supply.
  3. I need a cheap 600w power supply that has 1-6pin and 1-8pic PCI-E connectors for my graphic card
  4. What do you think of an aerocool xpredator case?
New Build Graphics Cards Components Motherboards Systems Product
