I'm looking into water cooling for my new build (along with sleeving and custom paint etc. [pretty bored ] ). I've read a lot of the threads and topics for water cooled cases, but since I have never done it before it's difficult to filter the information for what I am trying to accomplish. I'm looking for mid size or a shorter full size tower that is capable of housing the entire water cooled setup (radiator, pump, tubing, etc.) possibly with an external reservoir. I plan on cooling a 2600k (or better depending on what is available when I finish my case), and two high end graphics cards (haven't decided which two yet). I have found a lot of suitable cases, but there seems to be a lack of cases built with USB 3.0 that are radiator friendly. Cable management is a big plus also.
USB 3.0 cases:
IN WIN Dragon Rider (has 2 USB 3.0 that needs to be routed to back of case, very large...)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108376&cm_re=dragon-_-11-108-376-_-Product
Corsair Obsidian 650D (has 1 USB 3.0 needs to be routed to back of case )
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139004&Tpk=650D
Cases that seem reasonable but lack the usb 3.0:
HAF922
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119224&cm_re=haf_922-_-11-119-224-_-Product
The corsair case seems like the best option for what I am looking for at the moment. Anyone have any input / pictures of their USB 3.0 cases / suggestions? A link to a similar thread I might have missed works too
USB 3.0 cases:
HAF922
