ATI 5970 running temps
Hello,Can anyone tell me what temps my ati 5970 should run at, idle and load ?
3 answers Last reply
More about 5970 running temps
  1. I am also using msi afterburner to set up cooling
    idle is about 37 on gpu2 and 41 on gpu1
    under load playing bad company 2 they are gpu2 51 and gpu1 50
    fan speed is 41% but noisy
    can you advise
    there is a 140 mm fan on the bottom blowing up 200 mm on front blowing in and 200 mm on top blowing out, the back has the h70 fans 2 x120 mm
    its a coolermaster sniper ati case.
    I dont know if the fan on the card takes air in from the back vents or the fan blows it out to the back vents ?
  2. Your temps are about right.
    At 44% my fan is barely audible, but your hearing may be more sensitive then mine.
    To double check that MSI is not giving you a false reading try GPU-Z : http://www.techpowerup.com/downloads/1930/TechPowerUp_GPU-Z_v0.5.1.html
    can you advise
    Hi your temps are good ,but noisyyy, I got hold of a accelero about £40+ but temps way down and not a sound,mack.
Radeon ATI Graphics
