I'm using the Chaser MK-1 as my computer chassis and everything's great except for the fact that I don't know where to connect the rear fan to get it to work. My motherboard is the ASUS Crosshair V Formula and my PSU is the OCZ ZX Series 850Watt 80+ Gold. I can't find anywhere on the Crosshair V Formula to connect it to. The rear fan is a 140 mm x 140 mm x 25 mm TurboFan 1000 RPM 16 dBa fan with a (excuse me for not knowing the correct term for the connector) connector with 3 small square holes in it that seems to be where 3 pins would go into.
If anyone can check out those parts and see where it would go to get it to run, it would be greatly appreciated. Thank you.
Links:
Chaser MK-1
http://www.thermaltake.com/products-model_Specification.aspx?id=C_00001719
http://www.asus.com/Motherboards/AMD_AM3Plus/Crosshair_V_Formula/#specifications
OCZ ZX Series 850W 80+ Gold
http://www.ocztechnology.com/ocz-zx-series-850w-power-supply.html
Links:
Chaser MK-1
