Hi guys, i havnt made a system in over 6 years and im probably a little behind. Ive done some research and made a setup and was wondering if its any good. Here is what im planning on getting. Im planning on doing a slight budget build with some overclocking ability.
GIGABYTE GA-P67A-UD4-B3 LGA 1155 Intel P67
CORSAIR CMPSU-750TX 750W ATX12V v2.2
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
Western Digital Caviar Black WD6402AAEX 640GB 7200 RPM SATA 6.0Gb/s
Intel Core i5-2500K Sandy Bridge 3.3GHz
I am going to use my current case and I plan on running sli with my BFG 8800gt oc's
my main concern is the power supply and ram, and input would be much appreciated, thanks.
