Solved
Would this power supply be good for my components?
  • Power Supplies
  • Cooler Master
  • Components
  • Product
Last response: in Components
Anonymous
July 12, 2011 10:14:24 AM
MY setup:
Intel i5-2500k
MSI P67
1TB Hardrive
CM Hyper Cooler +
8GB DDR3 dual channel...
XFX 6870 GPU
Anyways i need to choose between the "Corsair HX650 Powersupply" or the "Cooler Master 600W silent pro"
these are both modular and cheap-ish power supplies over 600Watts, I'm not planning to crossfire my cards though. Corsair is probably the top notch but the cooler master IS $30 cheaper and i am on a budget.
Will the cooler master power be enough for my setup non crossfire?, I might add a few hardrives in and maybe more ram later on...
More about : power supply good components
Anonymous
July 12, 2011 10:55:34 AM
^^ That one is too expensive, i need atleast $70-$80 after rebates, BTw if i do get the corsair then i need to downgrade my gpu to a 6850
m
l
Anonymous
July 12, 2011 11:52:52 AM
^^ Thanks guys, I might get a 6850 with the corsair or the cooler master with the 6870
m
l
Anonymous
July 12, 2011 12:33:39 PM
^^ That looks pretty good but I'm not Modular.
m
l
Anonymous
July 12, 2011 1:16:34 PM
Quote:
dont see anything wrong ith that coolermaster, it has a great jonnyguru review:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
and should be able to run that system fine.
Great! Thanks, And since i don't game that much should i buy a 6850 dual for to save $15 or save 30$ with the one fan
m
l
July 12, 2011 1:22:57 PM
what games do you play and at what resolution? That really decides what card or cards you will need.
m
l
Anonymous
July 12, 2011 1:46:21 PM
At 1920x1080, And i play: cod4, cod5, tf2 <--- Online, And i love playing campaigns for games like medal of honor and such...
The 6870:
Has 6870 ram combo and Dual Fans - Very good cooling
Better Performance
Only $15 more because the 6850 (Dual Fan edition) has no combo deal with RAM
It is a very tight fit into the nzxt m59
The 6850:
$30 less if i get the non dual fan 6850
On a budget
will fit better in my case, its 9.25inch
m
l
Anonymous
July 12, 2011 1:48:10 PM
and im really hesitant whether or not my psu will handle it... hmm you said it will so i guess it will, obviously the 6870 is a better deal but its very tight in my case
m
l
Best solution
July 12, 2011 1:53:37 PM
Any of the power supplies mentioned should handle your setup with a 6870. My personal favorite is Seasonic, but the others should be ok. For 15 dollars more the 6870 is more than worth it over the 6850. As far as it fitting in your case, I would definitely recommend doing some measuring before you buy. Nothing would suck more than getting a nice new shiny card and find out it won't fit.
Anonymous
July 12, 2011 2:03:47 PM
Best answer selected by Altay.
m
l
Anonymous
July 12, 2011 2:04:01 PM
thank you! Awesome help
m
l
