Hello,
I am building my first computer as i type this, and have a questions I can't find the answer to on these forums. Chances are I missed it b/c it seems a fairly easy question, but I don't want to mess something up.
My motherboard:
GIGABYTE GA-Z68X-UD3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128498
My PSU
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Question is this...
I connected the 24 pin power cable, but I don't see any 4 pin or 8 pin 12v connector. This was mentioned in this thread: the only connectors with that PSU are the sata connectors, 4 pin molex connectors, and the PCI-e connectors.
http://www.tomshardware.com/forum/274745-31-step-step-guide-building
Should I have this connector, or is the 24 pin connector all I need?
Thank you for your help
My motherboard:
My PSU
Question is this...
